Remove the manual lock knob by prying the little square piece out of the front, if there is a screw there remove it(t-15 torx). Pry the little plastic cover out behind the inside door handle, and there is a phillips head screw behind it. Pull out around the outsides of the panel and lift. Cant guarantee that you won't break some pin style retainers, or the locating datums, they are sometimes casualties you can't avoid.
SPONSORED LINKS
Thursday, July 23rd, 2009 AT 9:34 PM
