2000 Cadillac Deville valve tapping
56,000 MILES • V8 • 2WD • AUTOMATIC
BIGEC4000
  • 9 POSTS
I JUST CHANGED MY SPARK PLUGS. (BOSCH PLATINUM 2+). NOW I HAVE A TAPPING VALVE WHERE I REPLACED A WORN SPARK PLUG. THERE WAS A LIL DEBRIS THAT POSSIBLY FEEL THROUGH THE SMALL HOLE. MY NEXT STEP IS TO REMOVE VAVLE COVER AND FIND TAPPING VALVE AND REMOVE DEBRIS. DOES THIS SOUND LIKE A POSSIBLE ROUTE?
Apr 7, 2009 at 9:41 AM
FACTORYJACK
  • 4,159 POSTS
Your not going to get any debris out by removing the valve cover. If you suspect that something went into the combustion chamber, remove the spark plug and run it or crank it. The compression pressure may blow it out.
Apr 7, 2009 at 2:38 PM
BIGEC4000
  • 9 POSTS
SO THE DEBRIS WENT IN COMBUSTION CHAMBER.......WHAT IS CAUSINNG THAT TAPPING IN THE VALVES THEN.
Apr 7, 2009 at 3:31 PM
FACTORYJACK
  • 4,159 POSTS
If you think the debris went through the little hole, it ended up in the combustion chamber. Removing the valve cover would put you in the valve train, no debris that went through the spark plug hole would be found in the valve train. It sounds like you had some porcelain make it's way into the combustion chamber. You can run it, it will eventually turn the porcelain into dust and process it. Pulling the valve cover would expose nothing that you could have created. Having not heard the noise, I can only suspect. It may be the result of carbon on the pistons causing noise as well.
Apr 8, 2009 at 9:57 PM
