2000 Cadillac Deville deville won't start
97,000 MILES • V8 • FWD • AUTOMATIC
HEAVYED85
i installed a sound system in 00 deville was draining my battery so i replaced the original battery with a optima batt fix that problem. Ran fine for two days then i tried to start it the starter doesn't turn over all i get is a clicking noise in the fuse box underneath the rear seat.The alarm does't seem to be working right either when i arm it and leave the window down unlock it manually the alarm does't go off like it supposed to i would really appreciate any help.A mechanic told me it might be the ignition switch.
Sep 12, 2010 at 5:47 AM
FACTORYJACK
  • 4,159 POSTS
If you had a concern with draining the battery, replacing the battery would not have solved it. In theory, it would still be draining. Have you taken a measurement of battery voltage, or tried jump starting? With the security system, have you tried arming it, and manually opening other doors? I am assuming during your check, you lock the doors with the remote, and wait until the security light goes out, and then try manually unlocking and opening a door.
Sep 13, 2010 at 5:11 PM
