2000 Cadillac Deville air conditioning
TONY LONIERO
  • 2000 CADILLAC DEVILLE
  • V8
  • 65,000 MILES
There is a clicking noise under the dash and air does not come ut of the vents
Sunday, March 9th, 2008 AT 7:13 AM
MERLIN2021
  • 17,250 POSTS
Can you hear the blower motor run? First thing to do is have the error codes read by a shop that can read Body codes for Caddy. If blower runs but no air comes out, the clicking could be an actuator for a door in the a/c plenum. Either a door shaft needs oil, or the actuato needs to be replaced, but a scan will at least give a starting point!
Sunday, March 9th, 2008 AT 8:08 AM
BUZZSAW
  • 1,198 POSTS
You can pull the codes yourself, off and down on the mode button on the heater controls w/ key in the on position
is the noise down by the gas petel, there is an actuator right there, that 1 is usually the culprit
Monday, March 10th, 2008 AT 1:21 PM
