1997 Cadillac Sedan Deville
BAKERA
After my car sits for a while (more than 10 minutes) my aftermarket Kenwood CD player along with my cigarette lighter, resets. I verified that the yellow wire from the radio was connected to "constant power" (yellow wire). I switched the "red" and the "yellow" just in case the factory coloring scheme was backwards, this did not work, I switched the wiring scheme back. I checked the fuses, it is the right size fuse and they are all working. The car battery doesnt reset, just the radio and cigarette lighter.
Jan 13, 2006 at 5:11 PM
BAKERA
To fix this problem I re-wired the ground and constant power wire to run directly from the car radio to the car battery. Never resets now!
Jan 22, 2006 at 2:32 PM
DOCHEMI
[quote:5117f8984e="bakera"]To fix this problem I re-wired the ground and constant power wire to run directly from the car radio to the car battery. Never resets now![/quote:5117f8984e]
I am goingto take it he never read the manual or heard of accessorie power retention.
Jul 25, 2007 at 4:15 PM
