Dash shows low refrigerant reading Freon is not low
90,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
QUINTON KELLEY
keep getting very low refrigerant reading on dash panel. Freon is not low.
Jan 25, 2017 at 9:20 PM
HMAC300
  • 48,601 POSTS
if you are putting a temperature gauge there then you are reading the air temperature not the Freon level. you need gauges hooked up to system to read that. if your readings are in the forty some degree area on the air temperature then nothing is wrong.
Jan 25, 2017 at 10:06 PM
