1996 Cadillac Deville Lock out selnoid
126,000 MILES • V8 • FWD • AUTOMATIC
BUTCH GA
126,000 miles. I am still getting a code that my Troque convertor lock out selnoid is not working properly. My question is WHERE IS THE SELNOID LOCATED? I made a donation and asked this question and the response I received was NOT correct,(see attachment) any information on this will be greatly appreciated.
sorry, no donation this time
Jun 3, 2009 at 1:03 AM
FACTORYJACK
  • 4,159 POSTS
If your speaking of the TCC solenoid, it is behind the transmission side cover clipped in to the upper control valve body. It is primarily accessible with the transmission removed from the vehicle. If you plan to go as far to replace just the solenoid, there are other things to consider like fluid circuit seals, the converter itself, the valves involved, and potentially wiring. A successful repair will depend on an accurate diagnosis.
Jun 4, 2009 at 4:27 PM
