Car locks not working fuel display not reading
11,719 MILES • 0.8L • V8 • FWD • AUTOMATIC
BAMM THOMAS CLEMENTS
  • 14 POSTS
Battery light on, no power to doors, windows, seat's, remote trunk, fuel door, rear defroster and radio station, can you help?
Jan 15, 2017 at 1:31 AM
HMAC300
  • 48,601 POSTS
battery may be in poor condition. check battery including load test and make sure terminals are clean. most places do for free.
Jan 15, 2017 at 3:03 AM
RENEE L
  • 1,260 POSTS
Hi BAMM THOMAS CLEMENTS,
If you decide to check the condition of your battery yourself here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself. If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Jan 16, 2017 at 6:36 AM
  • 14 POSTS
Put a new battery in same thing and I have no mileage reading and fuel.
Jan 16, 2017 at 8:59 AM
SATURNTECH9
  • 30,868 POSTS
Is the battery light still on? Also, have you checked to make sure your alternator is charging?
Jan 16, 2017 at 11:22 AM
  • 14 POSTS
I will check it today and get back with you. thanks.
Jan 17, 2017 at 1:12 AM
SATURNTECH9
  • 30,868 POSTS
You are welcome. let us know.
Jan 17, 2017 at 3:06 AM
  • 14 POSTS
I checked alternator it is reading good.
Jan 22, 2017 at 12:30 AM
SATURNTECH9
  • 30,868 POSTS
Is the battery light still on with the car running? Also, what is the voltage reading with the car running at idle?
Jan 22, 2017 at 1:04 AM
SATURNTECH9
  • 30,868 POSTS
Also, have you checked all the fuses?
Jan 22, 2017 at 1:05 AM
  • 14 POSTS
It was fourteen volts.
Jan 22, 2017 at 1:07 AM
  • 14 POSTS
Yes and light is still on.
Jan 22, 2017 at 1:08 AM
SATURNTECH9
  • 30,868 POSTS
How about the battery light is that still on with it running? also, have you checked all the fuses yet?
Jan 22, 2017 at 1:20 AM
  • 14 POSTS
Fuses are good.
Jan 22, 2017 at 1:24 AM
SATURNTECH9
  • 30,868 POSTS
Did this all start from a dead battery jump start etc? How you had it scanned with a professional photographer scan tool that can read all the computers in the car yet?
Jan 22, 2017 at 1:27 AM
  • 14 POSTS
Scanner keeps reading error and yes from dead battery.
Jan 22, 2017 at 1:32 AM
SATURNTECH9
  • 30,868 POSTS
You just tried a diyer scan tool? Sounds a lot like a bad body control. I have seen them fail after a dead battery just start etc.
Jan 22, 2017 at 1:37 AM
  • 14 POSTS
Next step.
Jan 22, 2017 at 2:24 AM
HMAC300
  • 48,601 POSTS
check the fusiblelink going to alternator as well for battery light problem but also have a mechanic scan for codes like Saturn tech 9 advised
Jan 22, 2017 at 4:58 AM
  • 14 POSTS
OK get back with you thanks
Jan 22, 2017 at 6:35 AM
  • 14 POSTS
Where's body control located
Jan 22, 2017 at 7:32 AM
SATURNTECH9
  • 30,868 POSTS
I am sorry there isn't a body control module on that car they just use a lot of different module to control different things.That is another reason I suggested having the car scanned with a professional scan tool to see what modules are able to communicate with and what modules have what codes. Also, which fuse boxes did you check the fuses in where were they located?
Jan 22, 2017 at 10:26 AM
  • 14 POSTS
Where is the body control located?
Jan 23, 2017 at 1:20 AM
  • 14 POSTS
Under back seat and under the hood?
Jan 23, 2017 at 1:23 AM
SATURNTECH9
  • 30,868 POSTS
Please read the above post above the last time you posted where is the BCM?
Jan 23, 2017 at 4:24 AM
