1995 Cadillac Deville WIRING PROBLEM
130,000 MILES • V8 • FWD • AUTOMATIC
CHRIS2040
I stopped for gas filled up and was about to leave station.I started the car and the E started flashing on gas gauge I turned on headlights and the warning chime came on that you get when you take the key out and leave the lights on.Also at the same time I lost power to AC COMPRESSOR-BUTTON TO OPEN TRUNK and BUTTON TO OPEN GAS CAP DOOR.I checked all fuses and the 4 relays on top of drivers side wheel well and fuse panel in trunk all ok,what now?
Jul 3, 2009 at 9:01 AM
FACTORYJACK
  • 4,159 POSTS
Could the chime have came to indicate low fuel?, it sounds like you have more than one problem. On the flashing E and the chime, You could have a sender that is failing indicating false low fuel, or gauge inaccuracy. The fuel door-gas door issue, does it have a valet lockout switch that could be on? Is the climate system defaulting to econ, auto not selectable?
Jul 4, 2009 at 10:45 AM
