WHAT CAUSES THE ENGINE TO OVERHEAT AND WHAT CAUSES LOW OIL PRESSURE
Wednesday, February 10th, 2010 AT 8:31 AM
FACTORYJACK
MECHANIC
There is no one cause for either. The overheat can be caused by faulty thermostat, faulty water pump, blockage in radiator, inoperative cooling fans, internal leak(headgasket/crack) to name a few. The oil pressure could be low from a faulty pump, faulty sender, mechanical faults, improper repairs.
