1994 Cadillac Deville car wont start!
95,000 MILES • V8 • FWD • AUTOMATIC
SLOPOK
I drove the car in to my parking space fine. next day I try to turn it on ,it wont even make a noise. I know it's not the battery because it's new, and everything works on the car (headlights, interior lights, dashboard etc.). about 2 days later I try to turn it on and like it wanted to start but the battery went low after a couple of try's. So i try to jumpstart it but again it won't even make a noise when I turn the key. If you guy's can help me out I would really appreciate it.
Mar 7, 2008 at 7:19 AM
  • 75,988 POSTS
Get the battery load tested to check its internal condition and make sure its properly connected/cleaned and tight then retry-Don't work come on back. We still got a long way to go to nail this culprit.
Mar 7, 2008 at 7:35 AM
BUZZSAW
  • 1,198 POSTS
[quote:750597cfcb="rasmataz"]Get the battery load tested to check its internal condition and make sure its properly connected/cleaned and tight then retry-Don't work come on back. We still got a long way to go to nail this culprit.[/quote:750597cfcb]
Caddy battery cables corrode bad. ck for greeness around the cables, just to help Razzy. ck for power from the key to the starter, its a purple wire going into the intake
to me it sounds like a bad battery or cables, cause you cant jump it
Mar 7, 2008 at 8:43 AM
