1993 Cadillac Deville loss of acceleration
94,800 MILES • V8 • AWD • AUTOMATIC
CAR_SICK
loses power to acceleration, backfires, sputters, this also happens when air is on or turn signal is used.
Oxygen sensor was changed out but did not fix problem.
How could the turn signal and air be related to this problem???
PLease help!
Jan 12, 2009 at 2:20 PM
MMPRINCE4000
  • 8,548 POSTS
Take the car to any autoparts store and have the battery/charging system tested. Low voltage will cause many problems. If battery or alt. is bad, replace them.
The AC and turn signal could be related because they require additional amps/volts, and that is why I am suggesting to check the battery/charging system as a first step.
Jan 13, 2009 at 11:43 PM
