1992 Cadillac Deville car hasnt been started in over 2 year
TODD65
  • 1992 CADILLAC DEVILLE
Engine problem
1992 Cadillac Deville Engine Size unknown Two Wheel Drive Automatic 84,000 miles
I just inherited two cars from my deceased uncle this 92 cadillac deville has been in a garage for over 2 years and not started but is in excellent condition he was bed ridden for his last 2 years how do you recommend I go about getting it back to running and good condition without ruining the fuel system and seals.
Saturday, January 5th, 2008 AT 5:51 AM
BLACKOP555
  • 10,371 POSTS
First of all you need a new battery. Second clean all the terminals and connections of corrosion.
After that then you should drain all the fluid out of it and change the fuel filter, then refill it with fresh gas.
Next disconnect the coil and crank the car a few seconds, then reconnect and fire it up.
Saturday, January 5th, 2008 AT 9:30 AM
BLACKOP555
  • 10,371 POSTS
Before you do all that check your fluid levels!
Saturday, January 5th, 2008 AT 9:32 AM
