1996 Cadillac Deville cold starting problem
135,000 MILES • V8 • FWD • AUTOMATIC
BOBCOMMAN
When cold 32-40 degrees hard to start. 40-70 no problem .. What could be the cause???
Dec 15, 2007 at 4:02 AM
  • 75,988 POSTS
Get the coolant temperature sensor and idle air contol valve check-also the fuel pressure.
Dec 15, 2007 at 4:08 AM
BUZZSAW
  • 1,198 POSTS
[quote:6c5f29e33c="bobcomman"]Other Category problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 135000 miles
When cold 32-40 degrees hard to start. 40-70 no problem .. What could be the cause???[/quote:6c5f29e33c]
replace the fuel psi regulator, its on the fuel rail, tune due at 100k, has this been done?
Dec 20, 2007 at 9:40 AM
