1992 Cadillac Deville Car does not start
11,090 MILES • V8 • FWD • AUTOMATIC
BDHSOUJA
  • 7 POSTS
My 92 deville does not want to start when i put my key in the engine does not turn over nothing at all i brought a new battery thinking it was bad but still nothing.I have got under the car and checked my starter by tapping it and using a screwdriver to turn it on what can it be
Feb 8, 2008 at 4:49 PM
BLACKOP555
  • 10,386 POSTS
Will it crank with direct 12v applied to the starter?
Feb 9, 2008 at 12:25 AM
BDHSOUJA
  • 7 POSTS
Yes i have but car still does not start and engine does not turn over.And i have also took out the egnition module to get it tested and it was good so im still not sure what it can be now
Feb 9, 2008 at 4:24 PM
BLACKOP555
  • 10,386 POSTS
still have to help me a little more, when direct 12v is applied to the starter does the starter engage and crank the engine?
Feb 9, 2008 at 11:02 PM
BDHSOUJA
  • 7 POSTS
Yes when 12v is applied the starter does engage and cranks the engine but does not start the car
Feb 10, 2008 at 12:19 PM
BLACKOP555
  • 10,386 POSTS
if that is the case then you should replace the Starter relay, well work on the cranking problem first,
also check for loose or corroded cables, if those are all good and its not the relay then you may need a new ignition switch.
Feb 10, 2008 at 11:41 PM
BUZZSAW
  • 1,198 POSTS
[quote:35d77a91df="bdhsouja"]Yes when 12v is applied the starter does engage and cranks the engine but does not start the car[/quote:35d77a91df]
do you have a message across the insterment panel, wait 3 minutes before starting? or a scurity lite?
Feb 11, 2008 at 2:49 AM
BDHSOUJA
  • 7 POSTS
Well the only lights that appear wen the key is turned forward is the oil light with the pic of a oil pan and the charge light with the pic of a battery on the bottom left hand corner where it says information center,the secriuty light stays on.
And note that the car is not on the key is just forward cause like i said the car does not start and i have had my starter to get checked today and was told my starter is good not bad,could it be my ignition switch?
Feb 11, 2008 at 11:28 AM
BLACKOP555
  • 10,386 POSTS
It is probably the theft system, ill turn it over to buzzsaw, he is the caddy man around here.
Feb 11, 2008 at 2:27 PM
BDHSOUJA
  • 7 POSTS
Ok i really preciate that blackop555 but still most likey tomarow im goin to remove the ignition switch and see if that is what it is unless Buzzsaw knows 4 sure it is the theft system
Feb 11, 2008 at 2:32 PM
BUZZSAW
  • 1,198 POSTS
[quote:507ab19422="bdhsouja"]Ok i really preciate that blackop555 but still most likey tomarow im goin to remove the ignition switch and see if that is what it is unless Buzzsaw knows 4 sure it is the theft system[/quote:507ab19422]
the ign switch is part of the theft system, when you pull out the switch there will be an orange wire that hooks to it, if it is broke thats how the theft system reads your key, take an ohm reading of you key, the little slit thing in it, its a resistor, go to radio shack and buy the same resistor and put it in the orange wire, put the switch back in it and try to start it
Feb 15, 2008 at 8:39 AM
BDHSOUJA
  • 7 POSTS
Ok ima try that preciate dat mane let me try it and ill get bak at you
Feb 15, 2008 at 12:21 PM
