1992 Cadillac Deville air shocks
149,962 MILES • V8 • 2WD • AUTOMATIC
G022489
The factory air shocks automatically adjust with a pump located under the hood. After rotating the tires I found that the shocks did not pump up or adjust any more (pump did not turn on). It is my understanding that there is a leveler switch (located somewhere near the rear of the car) that operates the pump, as necessary, to raise the rear of the car. Do you happen to know where this switch is, if this could be responsible for the pump not operating, and how to clean it if it is responsible?
Dec 3, 2007 at 3:04 PM
BUZZSAW
  • 1,198 POSTS
[quote:9680c51e86="g022489"]Suspension problem
1992 Cadillac Deville V8 Two Wheel Drive Automatic 149962 miles
The factory air shocks automatically adjust with a pump located under the hood. After rotating the tires I found that the shocks did not pump up or adjust any more (pump did not turn on). It is my understanding that there is a leveler switch (located somewhere near the rear of the car) that operates the pump, as necessary, to raise the rear of the car. Do you happen to know where this switch is, if this could be responsible for the pump not operating, and how to clean it if it is responsible?[/quote:9680c51e86]
sounds like the lever poped off, the rod is attached to the rear lower control arm, ck it first
Dec 10, 2007 at 5:11 AM
