1990 Cadillac Deville Carbon build-up
74,000 MILES • V8 • FWD • AUTOMATIC
FRANK EMMITTE
I purchased a 1990 Cadillac. This car had been sitting for quite awhile. When I changed the oil it was like mud. A week or two later I changed it again, but I had not driven it because of other work being done new distributer, new plugs and wires It is still missing the mechanic adjusted the valves (calibrate) How do I get out the carbon that has built up in the engine?
Jul 26, 2010 at 4:07 AM
FACTORYJACK
  • 4,159 POSTS
The valves are not adjustable, they are fixed n a rocker support shaft. Do you think carbon is causing your miss? 90 was a bad year for fuel injectors, have those been checked. A resistance test of warm injectors should read 13-15 ohms. A lot less and the injector is shorted. To answer your question, top engine cleaner through a vacuum port, on a warm engine until it stalls, and let it soak for several hours. That is about the best you can do aside from engine disassembly, to remove carbon. Just be careful when introducing the cleaner, not to induce it at such high rate to potentially cause hydrolock.
Jul 27, 2010 at 5:10 PM
