1989 Cadillac Deville oil leak
JOHNNY0
  • 1989 CADILLAC DEVILLE
  • V8
  • FWD
  • 187,025 MILES
Oil is leakin from under the front driver side, it leake harder when the cars running, what is that?
Wednesday, January 9th, 2008 AT 10:26 AM
BUZZSAW
  • 1,198 POSTS
Which motor, 4.5/4.9, did you just have an oil change? Is the oil low?
When you change oil it gets traped when you remove the oil filter, drains down the back of the block and pools on the trans, then leaks, or oil cooler lines could be leaking
Friday, January 11th, 2008 AT 4:56 PM
