1995 Cadillac Deville Car leaking oil
SHILLBALLER15
  • 1995 CADILLAC DEVILLE
  • V8
  • FWD
  • 221,600 MILES
My car is leaking oil and sputtering as the oil is low. What should I check and where should I look to fix problem? I've just replaced the water pump and the radiator.
Sunday, May 25th, 2008 AT 7:37 PM
  • 31,937 POSTS
Hi there,
You will need to add oil to the correct level and give the engine a good wash down. Run & inspect for the leaks, if in doubt get your mechanic to inspect for you.
Mark (mhpautos)
Sunday, May 25th, 2008 AT 7:55 PM
BUZZSAW
  • 1,198 POSTS
Places the oil leaks are the oil pan and valve cover gaskets, or it burns it, in the morning after sitting all night have someone start it and look at the exhust pipe in the rear, is the smoke a bluish or whitish in color? Then its burning it
Tuesday, May 27th, 2008 AT 2:37 AM
