cadillac catera
CADILLAC CATERA
EYEFIXIT
  • 5 POSTS
have a 97 cadillac catera, have a code of p0455 and what is required to fix problem?
Oct 22, 2007 at 4:19 AM
2CARPRO JACK
  • 11,533 POSTS
That is a code for "large evap leak", check your gas cap, has to be there.should be a rather large obvious leak, look around the engine or the fuel lines/evap lines
Oct 22, 2007 at 7:37 AM
BUZZSAW
  • 1,198 POSTS
[quote:94bd1ba017="2CarPro Jack"]That is a code for "large evap leak", check your gas cap, has to be there.should be a rather large obvious leak, look around the engine or the fuel lines/evap lines[/quote:94bd1ba017]
if you replaced the cap with an aftermarket due to loss of cap, needs a cadillac cap, gas tanks are pressureized today a leak will cause a ck engine lite,
Oct 29, 2007 at 3:12 AM
