Did a top end rebuild on a V6 Catera, Engine is not starting. In following the insturctions for the Cam Gears 1,2,3,4... noticed that the Gears could be installed 180 degrees in either direction. Installed the timing belt using the correct tools, all timing marks matched correctly, Checked timing three times after manually rotating the engine clockwise 760 degrees each time. Wondering what is the correct procedure to ensure the cam Gears were installed correctly, and not 180 out?
Jun 28, 2009 at 1:15 PM
