2014 Hyundai Santa Fe C1513 Brake Switch Fix
46,891 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SIXTY6GTO
  • 95 POSTS
The battery on this car was drained and I suspect that the rear brake lights came on unexpectedly after parking the car for the weekend because the neighbor mentioned that. However, after jumping the car, charging the battery after driving the car and idling the engine, everything seems to be okay. I parked the car and brake lights did not come on overnight and the car started in the morning. The car has been okay since the one time the battery drained, but I feel that it is intermittent. Therefore, I took the car to AutoZone and it passed the battery, charging and starting system check. I also had the OBDII scanned, and everything was okay except the computer stored a C1513 Brake switch circuit error code. I suspect that the stoplight switch is intermittent. That is all I can think of. Any thoughts on this and if it might be the stoplight switch, can you provide detailed steps, diagrams and procedure to replace and adjust the stoplight switch please?
Jan 24, 2025 at 1:06 PM
STEVE W.
  • 15,411 POSTS
Those switches are failure prone so it could be a bad switch, or it could be the plastic pad that moves the switch, which pushes through the tap on the brake pedal. If the plastic bumper is gone you can usually use one of the push type "Christmas tree" fasteners sold to hold body panels in place. Just buy one that just pushes through the hole.
The switch is part number 938103S700. To replace it you remove the panel under the steering column by removing the screws shown. Then look on the top of the brake lever to find the switch. On the switch is a lock that you pull down, now rotate the switch 45 degrees so the locking threads release, and the switch can be pulled out. Unplug the connector. Now take the new switch and connect the wiring harness to it, then slip it into place in reverse of the old switch. Hold the brake pedal up and push the switch in until it bottoms out on the bumper on the pedal.
Let go of the pedal, if it stays up and the switch doesn't turn on the brake lights push the pedal and let it return, verify that the brake lights only come on when the pedal is pushed down and go off when it is up. Now rotate the switch counterclockwise to lock it in place and push the lock back into place.
https://www.youtube.com/watch?v=kNdQ2ptPNMg
Jan 25, 2025 at 4:39 AM
SIXTY6GTO
  • 95 POSTS
What do I do as far as the code C1513 stored in the computer which only was shown on the scanner at AutoZone and not my lesser quality OBDII scanner which had no powertrain DTCs or check engine light on. Disconnect the battery before changing the switch then re connect the battery after I replace the switch?
Jan 26, 2025 at 4:06 AM
STEVE W.
  • 15,411 POSTS
Once the switch tests good by the PCM it will count drive cycles and erase the code after a number of drive cycles. No reason to worry about it.
Jan 26, 2025 at 7:50 AM
SIXTY6GTO
  • 95 POSTS
Okay, thank you. I will be looking at the switch today and I will give you an update on what I found/did.
Jan 26, 2025 at 8:40 AM
SIXTY6GTO
  • 95 POSTS
I took a look at the switch and pedal area. I discovered that the pad that is supposed to be on the pedal was missing, and someone had put a metal screw of some sort in its place which was in the hole loosely. I am going to replace the pad of course. I am going to get the proper pad from the dealer. After I put the pad in, I am planning to replace the switch anyway which I feel would be a good idea since I am there, and the dash panels were pretty delicate to remove without breaking them. I read your instructions and watched the YouTube video you included, and I hope that putting the switch in, turning it, locking it in, and adjusting it is easier than it looks on the video (guy's hand was in the way). I thought I would upload a video so you can see what I found. The switch itself appears to be an original one due to the writing on the outside of it. Any thoughts?
Jan 26, 2025 at 11:44 PM
STEVE W.
  • 15,411 POSTS
Well, that was almost a repair! I would replace the screw as it looks thinner than the normal bumper so it may not be pushing the plunger in fully. The plastic is always "fun" it starts to get brittle after about 6-7 years. The main issue with the switch install is because of the location, it's hard to grab it real solid and you don't have a lot of leverage.
Jan 27, 2025 at 5:51 AM
SIXTY6GTO
  • 95 POSTS
I completed the replacement of the switch and the new bumper. I purchased the bumper from the local dealer for about $5. The new switch I got from AutoZone for $25-$30. Here is a video of the completed job. Thanks for your help! I will have the owner drive it for a few weeks then we will take it back to AutoZone and scan the car for the codes. We'll see if the C1513 code clears. It should. Then I will reply again and confirm that.
Jan 30, 2025 at 12:55 PM
STEVE W.
  • 15,411 POSTS
You do realize that putting a new part on an 11 year old car means that other parts will start failing because they are jealous? The code should clear on it's own as soon as the system sees that the switch is now working, but clearing it on it's own isn't a bad thing either.
Jan 30, 2025 at 3:40 PM
STEVE W.
  • 15,411 POSTS
Should be the Light blue for the turn signals, but trying both won't hurt anything.
Jan 30, 2025 at 3:42 PM
SIXTY6GTO
  • 95 POSTS
did you send the wrong message regarding turn signals?
Jan 30, 2025 at 3:49 PM
STEVE W.
  • 15,411 POSTS
Well that is strange. That was supposed to go to a different question. Please disregard. Not sure why it turned up here.
Jan 31, 2025 at 8:28 AM
Suggested Repair
Replace the brake light switch (part 938103S700) and the missing brake-pedal bumper/pad. Remove the lower steering-column panel, unlock and rotate the switch out, install the new switch and pad, then adjust it so the brake lights come on only when the pedal is pressed. Code C1513 should clear on its own after the PCM confirms the switch works over several drive cycles.
Conversation Summary
A 2014 Hyundai Santa Fe had a drained battery and stored code C1513, brake switch circuit error, with no check-engine light. The owner suspected an intermittent stoplight switch. The expert said these switches commonly fail and that the plastic pedal pad that actuates the switch can also be missing, and gave replacement and adjustment steps. The owner found the pad missing and a loose screw in its place, then replaced both the bumper and the switch. The expert said the code should clear after drive cycles once the system sees a working switch. A later turn-signal comment was a misdirected message and should be disregarded.
