1996 Buick Skylark Starter
1996 BUICK SKYLARK
137,000 MILES • 4 CYL • FWD • AUTOMATIC
MOOTYPECOW
I know that the starter is going bad. It spins and spins, most times it will catch but there are times it won't. Where is the starter located, what tools do I need to change it out and how long should it take an amateur? Thanks!!
Sep 11, 2009 at 2:12 AM
  • 110,241 POSTS
It is on the front of the engine at about oil pan height and is held in by 2 bolts. Make sure to disconnect the battery before removing it. If you have other questions, let me know. Also, figure around 2 hours.
Sep 29, 2009 at 2:56 AM
