1991 Buick Skylark hose routing
TAMSCAR
  • 1991 BUICK SKYLARK
  • 6 CYL
  • FWD
  • 140,000 MILES
I put in a new water pump and thermostat but motor still gets very hot very fast. I would like to find a hose routing diagram from radiator to motor then through the heater core to see if I crossed any hoses, or maybe there's another reason for the extremely hot engine. I also did a flush to the system. Everything is clean now. Any help would be appreciated.
Thursday, September 4th, 2008 AT 3:07 PM
Could be air lock in the cooling system try bleeding it-don't work-Do below
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following:, Pressure test the Rad. Cap, Clogged radiator, air lock in the cooling system, Fan clutch, Radiator electrical fan, collaspe hoses, water pump
Thursday, September 4th, 2008 AT 3:21 PM
