Engine Mechanical problem
1992 Buick Roadmaster V8 All Wheel Drive Automatic
carburetor is runnin to much gas how do I fix it
Wednesday, October 7th, 2009 AT 9:47 PM
MECHANIC
The car is fuel injected and doesn't have a carb. The air fuel mixture is measured by sensors that send a signal to the computer which then adjusts it.
Has the check engine light come on? Have you ever changed an O2 sensor on it? Does it still run well or is it loosing power?
LEt me know.
SPONSORED LINKS
Friday, November 6th, 2009 AT 7:56 AM
JANEL25
MEMBER
Yes engine light has been on, have not change the O2 sensor. It runs good but if I was to drive it, it wont get up to speed like it should.
