1989 Buick Riviera Trunk Won't Close
WINNIEELAYNE
Hi. My son has a 1989 Buick Riviera 168000 miles and a 6 cyl 3.8L engine. The trunk will shut but it will not close completely. We bought a new trunk pull down motor and replaced the old one and replaced the fuse, but it still wont close completely. I dont hear the motor trying to close it, but I have no idea. Help!! Thank you.
Windi
Nov 2, 2007 at 10:07 AM
2CARPRO JACK
  • 11,533 POSTS
Is the fuse still good or did it pop? Everything plugged in? Might want to get a test light and check for power at the latch.Also check the ground for good connection. Plus check the power relay that controls the truck latch operation to find that you will need a manual. check here https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 5, 2007 at 6:18 AM
Suggested Repair
Confirm the fuse is still good and all connectors are plugged in. Use a test light to check for power at the trunk latch, verify the ground connection, and test the power relay that controls the latch. A service manual may be needed to locate the relay.
Conversation Summary
The owner of a 1989 Buick Riviera says the trunk shuts but does not close completely. Replacing the pull-down motor and fuse did not fix it, and the motor is not heard running. The expert recommends checking the fuse and connections, testing for power at the latch and a good ground, and checking the trunk latch power relay with help from a manual.
