1999 Buick Riviera Wipers
1999 BUICK RIVIERA
91,000 MILES • 6 CYL • FWD • AUTOMATIC
SPARECHG
Wipers only work in wash mode. Any ideas?
Jun 26, 2008 at 3:22 AM
MMPRINCE4000
  • 8,548 POSTS
First check all the fuses, just in case. If OK then check for power at wiper motor connector with ign. on and wiper switch on. If no voltage, then the switch is bad.
Jun 27, 2008 at 3:28 AM
SPARECHG
I was afraid of that, only one wire hot at motor...no voltage on yellow or purple. I think they are high and low.
Switch is very expensive, entire turn signal lever.....wanted to be sure before I ordered. Thanks
Jun 27, 2008 at 3:46 AM
