1996 Buick Riviera #6 cylinder low compression
57FORDJOSH
  • 1996 BUICK RIVIERA
  • 6 CYL
  • FWD
  • 2,000 MILES
My car was fine and then I started to hear a little ticking but it only got worse so I shut it off quickly I took it to my shop and took the plugs out #6 was bent over to no gap not smashed I did a compression test # 6 had 30 psi #4 had 110psi the ticking only occured like when you rev it up and it starts comming back down to idle the car still runs pretty good it just acts like it has a SMALL miss but 30psi scars me alittle and the tick getting worse 3800 supercharged series ll
Monday, February 1st, 2010 AT 6:38 PM
  • 31,937 POSTS
Hi there,
You will need to get a leak down test done or have wet & dry comp test done to identify where the comp is going, we need to know this first.
Mark (mhpautos)
Monday, February 1st, 2010 AT 6:44 PM
