My turn signal has stopped working, but at times attempts to work, but "struggles" if you will. My emergency lights work perfectly and all my bulbs are good. I located and replaced the flasher I found under my steering column, but it didn't change anything. I was told that there are separate flashers for the turn signal and emergency flashers. I've located one, but can not find the other. I'm not sure if I replaced the correct flasher. Any advice or recommendations?
Nov 9, 2010 at 4:37 AM
