HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Riviera
Engine
Symptoms
Not Running
SPONSORED LINKS
1965 Buick Riviera restart
65BUICKOWNER
MEMBER
1965 BUICK RIVIERA
V8
2WD
AUTOMATIC
89,000 MILES
Runs great but after driving twenty miles or so it will not start back until it cools down. Not even turns over. Can you help?
Sunday, May 2nd, 2010 AT 4:26 PM
MECHANIC
Not even turns over. Are you referring this as ( When you turn the key to starting position nothing happens )?
Could be vapor locking try sealing the fuel pump from the exhaust manifold
SPONSORED LINKS
Sunday, May 2nd, 2010 AT 4:33 PM
65BUICKOWNER
MEMBER
Thats correct it does nothing when you turn the key back on to strart.
Sunday, May 2nd, 2010 AT 4:43 PM
MECHANIC
Short out the starter solenoid and see what happens if it cranks the engine over if so check and test the neutral safety switch and ignition switch
Sunday, May 2nd, 2010 AT 11:11 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1996 Buick Riviera My Car Will Not Start
Hi My Name Is Reggie And My Buick Riviera Will Not Start. When I Put The Key In The Ignition And Turn It, It Cranks But Will Not Start What...
Asked by
funnyman21
1 ANSWER
1996
BUICK RIVIERA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1995 Buick Riviera Engine Will Not Start
1995 Buick Riviera 6 Cyl Front Wheel Drive 100000 Miles This Is A Supercharged 3.8 With A New Supercharger That Has Been On The Car For...
Asked by
airplane99tr
26 IMAGES
1995
BUICK RIVIERA
Car Wont Start When Cold
Asked by
glenda
1 ANSWER
1989
BUICK RIVIERA
1995 Buick Riviera Car Wont Start, Electrical
My 95 Riviera Supercharged Wont Start. Replaced The Battery And Starter. When I Turn The Key They Car Clicks Once And Then Everything Dims....
Asked by
zrakvir
1 IMAGE
1995
BUICK RIVIERA
1990 Buick Riviera Will Not Start
The Security System Light Comes On And Will Not Let The Car Start
Asked by
todd1070
1 ANSWER
1990
BUICK RIVIERA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
