Rear Hatch
MAG1GIE
My 2006 Buick Rendezvous rear hatch will not unlock. A piece of fabric is lodged between the "hook and eye" of the door. The electric release "clicks" but the hook does not move. All the fabric has been removed that can be reached. Is there a manual release? No info is found in the car manual. thanks!
Oct 20, 2007 at 11:32 AM
MERLIN2021
  • 17,250 POSTS
You may have to use the key and pull real hard...
Oct 20, 2007 at 11:48 AM
MAG1GIE
[quote:f533c8d2af="merlin2021"]You may have to use the key and pull real hard...[/quote:f533c8d2af]
there is no lock for a key :?:
Oct 20, 2007 at 1:55 PM
MERLIN2021
  • 17,250 POSTS
Then what you should do is get a good rag, wrap it around a large screwdriver or prybar and as the switch is acctivated, pry up! The rag is to protect the paint!
Oct 20, 2007 at 11:56 PM
