2002 Buick Regal Steering Wheel Shake
KARENCAN
I have a 2002 Buick Regal with 115,00o miles on it
My power steering went out, I had it replace with a rebuilt pump, and it still didnt work. Plan on replacing the pump once more before the warranty is up.
Now my steering wheel shakes and it feels like something is loose It shakes while going slow, but if I get the nerves to go up to 55 mph its fine. I thought it was a bad tire, replaced the tire and there is still this shaking What can this be?
Jan 3, 2007 at 9:47 AM
SERVICE WRITER
  • 9,123 POSTS
Maybe it's something, minor, but if that front end (steering and suspension parts) haven't been looked, I start by checking for play in it. That may be a serious saftey issue.
Jan 3, 2007 at 11:17 AM
BLAHBLAH718293
when i got my '95 skylark it had what sounds like a similar problem but the wheel would start shaking between 75 and 80 mph. i think it ended up being the alignment that was the problem for me.
Jan 3, 2007 at 12:12 PM
Suggested Repair
Have the front steering and suspension inspected for play or loose parts, since that can cause low-speed steering-wheel shake and may be a safety issue.
Conversation Summary
The owner of a 2002 Buick Regal reports steering-wheel shake at low speeds that smooths out around 55 mph after a rebuilt power steering pump failed to restore assist. A tire replacement did not stop the shake. The expert recommends checking the front steering and suspension for play because it may be a serious safety issue. Another owner mentioned alignment on a different car, but that was not the expert recommendation.
