1998 Buick Regal Power Steering Loss
RFREESE
I have a 98 buick regal LS - it has 105000 miles on it with a v6 engine. I've recently started having an issue(s) with it. When I turn to the right I lose all power steering and have to basically make the wheel turn. It does not however do this when I turn the left. It makes a clicking sound when turning right. My car has also been sort of stalling and "jumping" after stoplights - not sure if these two things could be tied together or not?
Jun 11, 2007 at 1:44 PM
2CARPRO JACK
  • 11,533 POSTS
Might not be related. The P/S isuue sounds like the rack and pinion is going out. Sometimes the valving willl only work in one direction when the unit has lost a seal or the such. Have you had the caar tuned up? at 105k it is past due for a major tune (plugs, wires, fuel filter, injection service) Is the check engine light on or has it come on lately?
Jun 15, 2007 at 12:56 AM
Suggested Repair
Have the rack and pinion inspected for a failed seal or valve that works in only one direction. Separately, perform an overdue tune-up (plugs, wires, fuel filter, and injection service) and check whether the check engine light is on for the stalling and jumping.
Conversation Summary
A 1998 Buick Regal LS with 105,000 miles loses power steering and clicks when turning right, but not left. It also stalls and jumps after stoplights. The expert said the issues may be unrelated, suspected a failing rack and pinion, and recommended a major tune-up plus checking for a check engine light.
