1999 Buick Regal Power Steering Noise
MMEYERS2
I have a 1999 buick regal 3.8 not supercharged. When turning either direction it makes a noise like the powersteering fluid is low however I can not find where to add powersteering fluid I was starting to wonder if the unit was sealed?
Jan 26, 2007 at 12:49 AM
CARUNDELL
  • 602 POSTS
[quote:82cca6d468="mmeyers2"]I have a 1999 buick regal 3.8 not supercharged. When turning either direction it makes a noise like the powersteering fluid is low however I can not find where to add powersteering fluid I was starting to wonder if the unit was sealed?[/quote:82cca6d468]
Hey M,
Nope, not a sealed unit ....... p/s pump fill should be on the pass side of the engine OR under the plastic engine cover (remove oil fill cap and neck to remove the cover) let us know!
Chris
Jan 27, 2007 at 11:17 PM
BOBINYELM
The reservoir cap is almost impossible to see or feel. It is behind the engine on passenger's side up against the firewall (almost).
I hope you have small hands to get down in there! Use a mirror to locate it, then reach in by feel. Cap is about 1.5" in diameter and requites 1/2 counter clockwise turn to remove.
Bob
[quote:33a2cdd3e0="mmeyers2"]I have a 1999 buick regal 3.8 not supercharged. When turning either direction it makes a noise like the powersteering fluid is low however I can not find where to add powersteering fluid I was starting to wonder if the unit was sealed?[/quote:33a2cdd3e0]
Feb 10, 2007 at 2:48 PM
CARUNDELL
  • 602 POSTS
Thanks for the input Bob!
Chris
Feb 10, 2007 at 8:35 PM
Suggested Repair
The power steering system is not sealed. Locate the reservoir on the passenger side of the engine, possibly under the plastic engine cover (remove the oil-fill cap and neck to lift the cover) or behind the engine near the firewall. Use a mirror if needed, then turn the roughly 1.5-inch cap about a half turn counterclockwise to check and add fluid.
Conversation Summary
The owner of a 1999 Buick Regal 3.8 (not supercharged) hears a noise when turning either direction that sounds like low power steering fluid, but cannot find a fill point and wonders if the unit is sealed. Experts say it is not sealed. The reservoir is on the passenger side of the engine, possibly under the plastic engine cover, or behind the engine near the firewall. The small cap is hard to see and is removed with about a half turn counterclockwise; a mirror and careful reach by feel may be needed.
