1988 Buick Regal Dies When Warm
JKASSAY
1988 Buick Regal (only 59K) running fine til one day after idling in driveway for 5 or 6 minutes, I drove up the street and the car died a few blocks away. Tried to re-start; it turned over but would not run. Left it for 4 hours, came back; it started right up. Drove 3 miles and it died again. After 3 tries, it finally re-started and I was able to get ita mile home. Left it overnight, came back in the AM and started it right up. Drove 4 or 5 miles and it dies again. Would not start so I left it and came back the next day. Started, drove a few blocks, dies again. Hooked up a tester onto one of the spark plugs and find that there is spark and it fires even while engine dies. The fact that the car does run for a few minutes when cold makes me think the fuel pump is pumping. Thought engine might be over heating so I took out the thermostat...same results. Can this be some sort of malfunctioning sensor that shuts the engine down when it warms up ? Any other thoughts or advice?
Thanks...JK
May 24, 2007 at 3:55 PM
LSUSSEL
  • 252 POSTS
Have you checked the fuel filter?
May 27, 2007 at 3:56 PM
MADRAN34
It is your crankshaft sensor. It is located down by the crankshaft and you need a mechanic to do it since you have to remove the hermonic balancer to have it replaced
Jun 9, 2007 at 6:56 AM
Suggested Repair
Check the fuel filter. A reply also identifies a failing crankshaft sensor near the crankshaft; replacement requires removing the harmonic balancer and is typically a mechanic job.
Conversation Summary
A 1988 Buick Regal with 59,000 miles dies after a few minutes of driving, then restarts after sitting, including overnight. Spark is still present as it dies. Removing the thermostat did not help. An expert asked whether the fuel filter had been checked. Another reply said the crankshaft sensor is the cause and that a mechanic must replace it because the harmonic balancer has to come off.
