1998 Buick Regal Crooked Steering Wheel
JOHNL
After buying a new set of tires for my 98 Buick Regal, I took it to Brake Masters for an alignment. Before the alignment, when I hold my steering wheel perfectly straight (I try my best visually) the car tracks straight, even when letting go of the steering wheel. But after the alignment, I noticed the car leans right when holding the steering wheel straight, and in order to go straight, I have to pull the steering wheel slightly towards the left about 3-5 degrees, although, at this angle, the car doesn't seem to pull to any direction when I let go of the steering wheel. When I asked the technician at Brake Masters, they gave me various technical explanations of how every car and type of tires will have different alignment results etc., etc.. and that the steering wheel will not always be perfectly straight. Now, since this alignment was done on a computer-laser machine, am I being jerked around? Thanks for any input.
Dec 13, 2006 at 11:06 AM
JOHNBUKO
  • 9 POSTS
the best thing to do would be to check the tire pressure even though they are new. then look at the print out they gave you and see if the caster is less, or camber is greater on the right side. also look at the cross camber and caster(diff between each side) but it sounds to me like they didn't have the wheel straight when they tightened the tie rod locknuts. drive on the straightest, most flat surface you can find and see if the steering wheel is straight or not.
Dec 13, 2006 at 12:50 PM
IDRIVEATITLIEST
  • 15 POSTS
In my opinion. You bet you are.
Dec 13, 2006 at 1:21 PM
XOWEY
  • 113 POSTS
[quote:5f4e74826f="Johnl"]After buying a new set of tires for my 98 Buick Regal, I took it to Brake Masters for an alignment. Before the alignment, when I hold my steering wheel perfectly straight (I try my best visually) the car tracks straight, even when letting go of the steering wheel. But after the alignment, I noticed the car leans right when holding the steering wheel straight, and in order to go straight, I have to pull the steering wheel slightly towards the left about 3-5 degrees, although, at this angle, the car doesn't seem to pull to any direction when I let go of the steering wheel. When I asked the technician at Brake Masters, they gave me various technical explanations of how every car and type of tires will have different alignment results etc., etc.. and that the steering wheel will not always be perfectly straight. Now, since this alignment was done on a computer-laser machine, am I being jerked around? Thanks for any input.[/quote:5f4e74826f]
I would recommend that you talk to the manager and explain that your not satisfied with the alignment and ask to have it re-done or refunded . :wink:
Dec 13, 2006 at 2:22 PM
BOOTDOG
  • 665 POSTS
i agree with xowey, i did alignments for years, and there is no reason why they can't get the steering wheel straight. sounds like the "technician" who did the alignment either needs to slow down a bit or needs more practice
Dec 16, 2006 at 7:57 AM
CARUNDELL
  • 602 POSTS
[quote:7c2222c489="bootdog"]i agree with xowey, i did alignments for years, and there is no reason why they can't get the steering wheel straight. sounds like the "technician" who did the alignment either needs to slow down a bit or needs more practice[/quote:7c2222c489]
Hey!,
Here, here on straight steering wheels! ( I'm wicked anal about that too!!)
Chris
Dec 16, 2006 at 8:41 AM
Suggested Repair
Have the shop redo the alignment with the steering wheel locked straight, or request a refund. Also verify tire pressures and compare left-right caster, camber, and cross readings on the alignment printout.
Conversation Summary
After a computer alignment on a 1998 Buick Regal, the car drifts right with the steering wheel held straight and needs the wheel turned slightly left to track straight. Replies say the wheel should be able to sit straight, suggest checking tire pressure and the printout for unequal caster or camber, and recommend asking the manager for a redo or refund because the tie rods may have been locked with the wheel off-center.
