2002 Buick Regal Heater Fan
2002 BUICK REGAL
AUBE002
  • 7 POSTS
Heater problem
2002 Buick Regal 6 cyl Front Wheel Drive Automatic
Hey guys. My 2002 Buick Regal's heater fan isn't running anymore. It was working fine the other day then nothing. I checked the fuses and relays but nothing is wrong there. What could it be? Also I don't actually know where the blower motor is located on the car. I can't seem to see it under the hood. I am guessing it is blown. Let me know!
Feb 1, 2010 at 2:56 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. The blower motor should be under the passenger side dash. All repair info says to disarm airbags, where applicable, when working under the dash.
Once you get at the blower connector, you can unplug, turn on hvac, key on, check for voltage and ground at the connector.
Feb 1, 2010 at 3:27 AM
