I recently had my coolant system replaced, and now have problems with the air conditioning, which is not in the same area I am told. When I turn on the air conditioning it blow hot air on the driver side and cold on the passenger side, it has dual contols. I seem to even have heat when using just the vent, or when everything is turned off. could it be a damper stuck? and if so where is it located?
Oct 14, 2009 at 2:01 AM
