The ac blows cold air on the passenger side but hot air on the driver side
Wednesday, June 10th, 2009 AT 5:06 PM
MECHANIC
You need to check for vacuum leaks. The vents are actuated by vacuum. If there is a leak, the AC may not be directed to both vents. Check under the dash. With the engine running, listen for hissing sounds that may indicate a leak.
