1996 Buick Regal Transmission Fluid gone!
1996 BUICK REGAL
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOOGIE8797
Hi, my car wouldn't go into drive, reverse, etc. I parked it and noticed what appears to be a transmission fluid leak (pinkish fluid dripping behind oil pan on passenger side). I checked the transmission fluid level (car off). It has none!
Can you tell me how this might have happened and recommend my next step?
Should I take it to a transmission specialist?
Aug 25, 2009 at 1:31 PM
  • 31,937 POSTS
Hi there,
top up the fluid with the recommended type of transmission oil. and go get the leak checked, this just may be a leaking pan gasket so a transmission specialist can do this easily and may be get it serviced while it is in getting repaired as well.
mark (mhpautos)
Aug 25, 2009 at 1:35 PM
