1997 Buick Regal check level
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARY BETH
How do I check the transmission fluid level?
Sep 15, 2008 at 7:14 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:d310c78b31="mary beth"]Transmission problem
1997 Buick Regal 6 cyl Two Wheel Drive Automatic 160000 miles
How do I check the transmission fluid level?[/quote:d310c78b31]
Hello Mary Beth,
To check your transmission fluid you first run the car till it is at normal operating temperature. You will then, with engine still running, pull out the transmission dipstick you will be looking for marks about 1 1/2 inches - 2 inches from the tip. There should be an area the is cross hatched the fluid should be at the top of the cross hatched area, if it is half way between the area or less you will need to add some transmission fluid.
Sep 15, 2008 at 7:33 AM
