1996 Buick Regal Heater hose. How do I replace the heater h
1996 BUICK REGAL
VT2075
Heater problem
1996 Buick Regal 6 cyl Front Wheel Drive Automatic
How do I release the tension to replace my heater hose
Oct 8, 2008 at 8:38 AM
  • 110,244 POSTS
When you say releave the tension if it's a regular hose clamp, it will have a screw on it. Use a screw driver to turm the screw or I believe a 5/16 socket will fit. If it's a tension clamp, you need to squeeze the two prongs together with pliers.
Nov 15, 2008 at 4:53 PM
