I replaced the fuel pump on this vehicle and ir ran fine shut it off and it blew the 20 amp fuse I replaced the fuse with a breaker and it started a few starts later it did it again I removed the tank and ohmed out the wiring no short to ground My question is could the oil pressure cut out switch cause this issue
Dec 14, 2008 at 2:32 PM
