1992 Buick Regal fuel pump fuse
19CASASAO
Electrical problem
1992 Buick Regal 6 cyl Two Wheel Drive Automatic 100k miles
my 1992 buick regal will kep burnin the fuses for the fule pump it started out once every couple weeks now as soon as i place he fuse and reconect the batery it imediately burns it again could it be the fuel pump or a bad short somewere???
Oct 17, 2010 at 2:20 PM
SATURNTECH9
  • 30,869 POSTS
If it blow's the second you turn the key on try unplugging the fuel pump and then see if the fuse blow's.
Oct 17, 2010 at 2:32 PM
  • 75,988 POSTS
Could be the fuel pump try disconnecting the fuel pump connector and see what happen if it continues-try the fuel pump relay
Oct 17, 2010 at 2:34 PM
