1995 Buick Regal coolant level
166,000 MILES • 6 CYL • FWD • AUTOMATIC
MALLYMAL44
i changed the lower radiator hose on my regal.filled the coolant back to proper level,and now every so often the low coolant light comes on.i was told it could be the coolant level sensor.where is that located,and how can i check that to make sure that is the problem.thanks in advance
Apr 1, 2009 at 11:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It is located on bottom of coolant tank resevoir. Ensure connections/wiring is good to sensor. If sensor wiring it OK and coolant level is proper then sensor is probably becoming faulty.
Thanks for using 2CarPros.com!
Apr 1, 2009 at 5:32 PM
