1993 Buick Regal Oil pressure gauge is low
ANGEL41466
Engine Performance problem
1993 Buick Regal Front Wheel Drive Automatic 113999 miles
My oil pressure gauge is on the warning mark . Says to check gauges and when I pour oil in it leaks out .
Jan 20, 2010 at 4:41 AM
TOOOMANYTOYS
  • 513 POSTS
Can you see where the leak is coming from? It may be as simple as a loose drain plug or loose filter, but also could be more serious. Eitherway if the oil light is on, and there is no oil pressure engine damage can occur. I would sugguest having it checked as soon as possiable
Jan 20, 2010 at 5:07 AM
