1992 Buick Regal oh help
1992 BUICK REGAL
777PRINCE
Engine Mechanical problem
1992 Buick Regal 6 cyl Front Wheel Drive Automatic o miles
i just picked up this car drove it a short distance home . drove it short distance the next day . didnt notice when it warms up it will either die or if i shut it off warmed up it wont restart . turns over just fine , no spark out of plugs ... cools down will restart . . over 118,000 miles ,milage broke .... on a tight buget would love some advice thank you...
Nov 8, 2009 at 3:59 PM
  • CAR REPAIR CONTRIBUTOR
Hi 777prince and TY for the donation
Double check all connection with the ignition No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it system-
Nov 8, 2009 at 4:52 PM
