I think I've been here before, anyway, I successfully swapped my Vacuum harness.
The original problem was and kind of still is the engine will not idle on start, if you just barely feather the accellerator it will run. In about 3 - 5 minutes it will rough idle on its own. When the engine is completely up to running temperature it will idle almost smooth. However, a new problem has appeared since R&Ring the vacuum harness. It will now do a throttle burst every now and then.
So, in summary, cold engine no idle without assist and an occasional throttle burst.
What should I check now?
Thanks in advance!
Thanks in advance!
Feb 26, 2007 at 4:57 AM
