1991 Buick Regal
JIM MACNEIL
  • 1991 BUICK REGAL
1991 Buick Regal 6 cyl Two Wheel Drive Automatic
problem: stalls after about 30 min while driving. Changed crankshaft sensor, camshaft sensor, modulator, maf sensor, plugs, fuel pump & filter. Problem remains unchanged
Sunday, May 4th, 2008 AT 11:09 AM
MASTERTECHTIM
  • 4,750 POSTS
When it stalls does it jerk violently first then stall? Does it start back up?
Sunday, May 4th, 2008 AT 2:12 PM
JIM MACNEIL
No jerking, just dies. Restarts like new after 15 seconds. Help solve this problem & I'll be happy to send you some "clams". Thanx again, Jim
Sunday, May 4th, 2008 AT 4:36 PM
MASTERTECHTIM
  • 4,750 POSTS
This is a tricky one to fix on the internet but lets try tap testing the ecm. Which engine do you have?
Sunday, May 4th, 2008 AT 4:39 PM
JIM MACNEIL
Engine is 3800 series--3.8
Sunday, May 4th, 2008 AT 6:53 PM
MASTERTECHTIM
  • 4,750 POSTS
I woulkd lightly tap on the cranksensor with a long screwdriver and see if you can get it to stall. It is critical they are adjusted correctly. Also there are several grounds on a stud under the ignition module, I always remove the ignition module and grind down where it connects and where the grounds connect
Monday, May 5th, 2008 AT 6:43 AM
