1990 Buick Regal engine cut out
MCKK4
  • 1990 BUICK REGAL
  • 6 CYL
  • FWD
  • 126,000 MILES
Drove 2 miles and car engine quit like it ran out of fuel. Restarted it and off I go and then quit again. Pulled over restarted it 6 or 7 times quitting each time then started it and drove home.I can start it it will run till I run up the rpm's and the outcome is the same. Seems to run out of fuel. Can you help pinpoint the problem
Saturday, April 11th, 2009 AT 9:39 PM
  • 109,779 POSTS
First, if it feels like it is running out of gas, chances are it is. You need to check fuel pump pressure. Here is a how to video to help.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Also, is the check engine light on?
Let me know what you find.
Sunday, May 3rd, 2009 AT 4:49 PM
